Hi All. I have finally decided to go for it and build a scope that will meet my personal criteria.
One of which is ultra fast setup without the need to recollimate every time. (thank you string scope!)
Another of which is a one-person-managable weight (preferably light, but I don't travel that often and can handle a bit of weight if it means getting everything else I want...I just mean I don't need a 20 pound ultramodern ultralightweight for it's own sake. I consider a 50 pound scope totally managable but of course light is good). I'm especially keen on getting down to a very compact 'package', that, if I need to fly with it, I could, say at worst, put the primary in a carry-on messenger bag, and check the rest as some kind of self-contained and sturdy BOX (nested and collapsed), at best bring the whole thing with primary in tact onto carry-on, but really that is probably pressing it though others have gone to great lengths to do just that:
http://members.aol.com/radcash/travelscope.htm
(i also want ladderless viewing with high quality optics and while I was considering 15 inches to be my maximum to meet the goals for this scope, I came into what promises to be an outstanding refigured 13.1 if all goes right, so for now it's going to be a 13.1, and the longer the better but f/5 may be the limit for flat footed -ish observing as I am 5'11", taller in heels, but so awkward to observe in drag!
I am sold on doing a string scope, but now must decide whether to do one of those boxless rockers whatever you call them (see pic) or a nesting UTA-collapsed-into-RockerBox, coupled with ground board, to lock up into a convenient travel box (minus trusses). An excellent example built by an 'internet friend' and sometime contributor to this forum is seen here:
http://home.europa.com/~telscope/tanaka.htm
What I need help with guys is this: having decided a lot already (13.1, string, goal is collapsability and a managable weight), what kind of rocker should I execute and why? pros? cons of each. I'm a so so wood worker, and not at all a metalworker if that makes any difference to your suggestion. I just don't know the relative advantages or disadvantages of this radical rocker (see pic) versus the other links I've included and that should settle my overall design approach for now.
Thanks.
TomL
Thanks.
TomL
