Jay Messeroff
Lunar & Solar Transits
Thickness of Secondary
Started by D Brown, 12/27/2006 04:53AM
Posted 12/27/2006 04:53AM Opening Post
Hello All
We are in the process of building a 20 inch newt scope but owing to time factors, we have decided on purchasing a finished secondary. The problem we have relates to the correct thickness of the flat. We have been offered a 4.5 inch flat by a supplier but it is only 18-22mm thick. It does not quite meet the accepted ratio of 1:6 cited by the ATM community as the ideal size for mirrors, particulalty primaries (or does'nt it matter with flats)
We would be grateful for any advice.
Regards
Doug
Posted 12/27/2006 05:46AM #1
Hi Doug,
The flat is so small that there is little deformation from it's own weight when mounted. This makes the thickness not a great issue if a good secondary holder is used. Plus, it means less load on the spider assembly and less flexure in the assembly which is good.
Call a few makers and ask them what they recommend. I use Antares Optics secondary mirrors myself.
