Philip Imbrogno
Elephant Trunk Nebula
Tomorrow begins 8" refractor build officially
Started by Greg Shaffer, 12/20/2014 06:55PM
Posted 12/20/2014 06:55PM Opening Post
Finally moving ahead with my 8" (7.75"clear aperture x BFL 123 3/8") which translates out to F/15.919 and tomorrow a friend and I are going to build the mockup to determine the exact 9" tube length....using 4 pcs of 1"x10' aluminum tubing, a leather belt around the cell, some motorcycle tiedowns, duct tape and a pc of 10x10 plywood with holes for the tubes in the corners and the focuser mounted in the middle and a couple more tiedowns on the other end.....rough aligned with a laser and then propped up to look in the sky if the clouds co-operate....find infinity focus and take some measurements so I can order the tube from from hastings irrigation. Plan is to account for using binoviewers without OCS or barlow and then use focuser extensions when single EP viewing.
My friend is also a machinist and is making the backing plate and adapting the cell to the tube....
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
Posted 12/21/2014 02:04PM #1
This sounds like a fun build....keep us posted!
I have a 6" f15 TMB doublet that I plan to build with the same Binoviewer/Monoview goals in mind. I was thinking of constructing a square plywood tube for the prototype build to verify the precise length I need from Hastings. I need to find a machinist for the countercell and focuser back plate.
I'm interested in any lessons learned!
-Gary
