Tools for TM'ing: Panel Miter Station
Started by P. Lee Stock, 03/06/2004 08:57PM
Posted 03/06/2004 08:57PM Opening Post
I have a relatively small shop about the size of a 1.5 car garage. I measured it at 19' x 15' the other day, or 285 SF.
One thing you need if you want to cut plywood sheets on a table saw is space. Not having much, I had to come up with an alternative method: the circular saw panel miter station.
I've seen designs for small versions meant to replace a 10" or 12" miter saw, and I've seen vertical panel saws that can cut at 90-degree angles, but I have never seen the miter station I made anywhere else, shown below. It's sort of a cross between the panel saw, miter saw, and radial arm saw. It is extremely accurate after you make some test cuts to set it up before the first use--getting perfect 90-degree (perpendicular) cuts is a piece of cake.
It can crosscut plywood 48" wide or cut 36" widths at a 45-degree angle. You could make it larger, but this is about as far as you can reach across comfortably (and it helps to walk down the left side while cutting if the sheet you are cutting doesn't hang out too far, getting in the way).
Compared to a cheap table saw, this is MUCH better. And if you work exclusively with plywood, this may be all you ever need (once you make a 10-foot rip guide for your circular saw for lengthwise and diagonal cuts on 8-foot sheets). It fits perfectly over my double router table when I want to use it, and stores neatly against my shop wall.
Why the drawing instead of an actual photo? I accidentally destroyed mine with water (particle board became swollen and buckled) and I also accidentally cut off the some of the angle gauge section with my sabre saw... oops. I definitely will make another one.
If this is too complicated, or you simply want a way to make 90-degree/perpendicular crosscuts with a circular saw, you can use this principle to make a circular saw T-square. Most plywood or panel cuts are either parallel or perpendicular to a factory edge, and a T-square cutting guide takes up almost no space.
Try it--you'll like it!
Lee
P. Lee Stock's attachment for post 13825
