Treating Aluminum ???
Started by AstroKwang2, 06/11/2003 11:27PM
Posted 06/11/2003 11:27PM Opening Post
So, my aluminum tube arrived and there's some kind
of grease-like coating on the interior.
Can anyone suggest a solvent to remove it? And prepare
for the primer?
Kwang
Posted 06/11/2003 11:45PM #1
Kwang,
Likely a heavy solvent like MEK ( methyl ethyl ketone) or Acetone will cut the grease after wiping all that is possible off of the tube...
Then tape of a small area of perhaps 10 cm square and do a test patch to see if the paint sticks well...
Then a phosphoric acid primer will be used to etch the aluminum prior to priming and painting...
Yes lots of steps, but a finish that will last a lifetime...
JMHO
Preston
