LBN 576 - The Garlic Nebula
Tripod construction question
Started by sprange, 12/24/2003 03:36PM
Posted 12/24/2003 03:36PM Opening Post
I purchased some black walnut (which was fairly inexpensive) to construct some replacement legs for my LXD55. The design is a relatively generic adjustable type, composed of three planks for each leg (sliding center 1 1/4 x 2) which is easy to make, but I have no idea how to tackle the feet. Should I simply taper the center plank to a ¾” square, or is there a better method that uses commonly (ie Home Depot) available parts? Other options included placing a 3/8 threaded rod with a sphere attached. Thanks for any help!
Sean
Posted 12/26/2003 08:57PM #1
Hi Sean, These legs are also black walnut
and dampen the vibrations quite nicely.
Mirror grinder can be seen in back...
Regards Preston
Preston E's attachment for post 74479
