VDB 142 Elephant Trunk HOO
Ultra-precision machining (for Herb)
Started by tiafolla, 12/17/2006 04:41PM
Posted 12/17/2006 04:41PM Opening Post
Hi all (especially Herb),
I ran across this site and thought you would be interested. This company produces a line of optical lathes that use a single-point diamond tool to turn out surfaces that don't need any further optical correction or polishing. Check out these specs:
Surface Finish (Ra): ¡Ü 2.0 nanometers
Programming Resolution (linear): 1 nanometer linear Programming Resolution (rotary): 0.00001 degree
Motion accuracy Axial: ¡Ü 25 nanometers (1¦Ì¡±)
Motion accuracy Radial: ¡Ü 25 nanometers (1¦Ì¡±)
Feedback Resolution (linear): 34 picometer 8O
Feedback Resolution 0(rotary): .02 arc seconds 8O 8O
Straightness: 0.3¦Ìm (8¦Ì¡±) over 450mm full travel
Positioning Accuracy (rotary): ¡Ü 2.0 arc seconds
Freeform Curve Accuracy (P-V): ¡Ü 0.125¦Ìm / 75mm dia, 250mm convex sphere
http://www.nanotechsys.com/NanotechProducts.html
I have no association with these folks, I just found this fascinating and wanted to pass it on.
Tim
Posted 12/17/2006 04:45PM #1
Sorry, some of the greek symbols got lost. Here are the specs in English:
Surface Finish (Ra): 2.0 nanometers
Motion accuracy Axial: 25 nanometers
Motion accuracy Radial: 25 nanometers
Feedback Resolution (rotary): .02 arc seconds
Straightness: 0.3 microns (8 microinches) over 450mm full travel
Positioning Accuracy (rotary): 2.0 arc seconds
Freeform Curve Accuracy (P-V): 0.125 microns / 75mm dia, 250mm convex sphere
