I have always wondered how reliable and repeatable Astrosystems upper cage clamp mechanism is. In my mind, I imagined the clamp could pivot around the pin. A current ad posted by Gary Siegelman shows what I believe to be a homemade variant of Astrosystems' clamps, and the problem I always suspected might occur is clearly seen in his ad photo.
Does this actually occur with Astrosystems'... er, system? If so, I wonder if they ever considered using a second pin below the clamp pin that slides into the slot and prevents this racking motion? Clearly, to me, this would cause at least mild collimation issues. And how could you ensure you got it exactly the same each time? I suppose this doesn't mark the end of the world, but I am a stickler for rigid assemblies and also hate to fuss with assembly inaccuracy and collimation problems.
Lee
Lee
