Vibration dampening on a DOB
Started by fblue, 04/14/2004 07:16PM
Posted 04/14/2004 07:16PM Opening Post
I have a little vibration when tapped with my 12.5" DOB. I am trying to figure out what might be the cause and fix.
Anyone have any ideas?
This is the picture of it and you can see the construcion method.
The dampening takes about 3 seconds to stop the vibration.
Floyd
fblue's attachment for post 14985
Posted 04/14/2004 07:51PM #1
Floyd, the first area I would look at is the rockerbox/groundboard interface. The design on this unit is different than most I have seen where the groundboard is a solid piece, either square or round. How much surface area is in contact with the bottom of the rockerbox?
Walt
Posted 04/14/2004 07:56PM #2
I have some vibration from the rocker box where the lag screw goes into the base. I'm going to see about adding a metal sleave around the lag screw to act as a bearing so the wood isn't subject to friction. I'd be happy to hear how others have dealt with that.
Matt
Posted 04/15/2004 12:49AM #3
Michael,
You are right about the support for the Alt bearings. They are connected at the lower 1/3 of the circle.
Not sure what I could do about that.
Floyd
