Philip Imbrogno
Elephant Trunk Nebula
Want heavy? Old vertical mill machines?
Started by samg74, 09/20/2003 06:13PM
Posted 09/20/2003 06:13PM Opening Post
Anybody tried this: using a worn-out vertical mill to build a mount system ???
Vertical mills go into surplus by the thousands. The heads wear out and tables are expensive to replace. This equipment is very high quality machinery, running $4,000-100,000 new for cast iron turret v-mills.
The turret-casting type vertical mills are massive. One-ton is a minimum weight, even with the quill machinery and table removed. The very smallest column turret types have everything for ATM mecdhanical use.
Gearing for "RA" and "DEC" is integral for several of the larger types. The column-turret types have the integral "RA" capability.
Driving the positioning gears smoothly on a v-mill would be a challenge. Similar to the recent DIY GEM threads for technology.
Despite problems, seems to me that modern computer controls could be adapted to positioning a vertical mill for astronomy. A manual-positioned v-mill should be reasonably economical as a used, stripped item.
One mad idea: tilt the one-ton v-mill to make it polar. A one-ton or more cast iron GEM. The column axis does the RA, the head-tilt handles DEC. GEM grande !
Anybody done it ? Tried it ? Thought about it and rejected it for simple, obvious reasons ?
Yes, there's a "knee" at the front of v-mill machines that kills off 15-degrees of rotation. It's in the way. An inconvenience unless that's the bottom of a tilted GEM.
Also, this idea would be best for a permanent home. It needs a well-sunk reinforced concrete floor.
If this works out, an old $500 v-mill could provide a great home for a big refractor or a one-meter Newt.
Posted 09/20/2003 07:16PM #1
Very old turret vertical mill. Note that there is no columnar axis in the stand body. Just the quill/drill mechanism.
samg74's attachment for post 71463
Posted 09/20/2003 07:29PM #2
Here's a modern one-ton turret type. Imagine this cast iron mill without the upper drilling head, the work table, and the cranks associated with the work table.
Positioning would be done with the column axis (near the top of the main vertical section for RA) and the angular rotator (at the front-end of the top part of the stand for DEC.)
Want heavy ? Got it ! .... ;^)
samg74's attachment for post 71466
