Jay Messeroff
Lunar & Solar Transits
Weight vs Performance: Aluminum or Steel Cell?
Started by toml, 03/26/2004 04:08PM
Posted 03/26/2004 04:08PM Opening Post
Hi Guys, I'm wrapping up the cage for my 13.1" today and you may have seen some of my progress here, some of you helping out along the way - thanks!
This being my first scope, I am really feeling a kind of "You have to build one to know how to build one" sensation...
In particular, I am moving on to the cell and though trying to keep the whole scope light and in balance with a low profile box, I don't have a 'gut' feeling as to whether I will actually need extra weight in my box or not (except for some vague notion that more scopes seem to fight top rather than bottom heaviness, balance-wise).
This is affecting my decision to make my cell out of steel, aluminum, or even 1/2" plexiglass. The other side of the coin is strength of course, and although I and many others believe that most dobs are overbuilt (not necessarily a bad thing until you have to put lug them in and out of your car trunk like I will), I don't want to totally neglect the important issues of strength/flexure...and so my question (finally smile is....drum rolll....
Given where I am coming from (goals: lightweight, low profile 13.1"), is aluminum (or even plexi) an option, or is steel still the only good performer for a dob cell? What is the weight versus performace trade off here? If big gains on weight savings can be made for very little performance trade off if any, then I will go with aluminum.
Please note that my mirror is a 1 1/8" THIN 13.1 and is quite light (about 12 pounds).
I await your experienced responses...(thank you)
TomL
Posted 03/26/2004 04:32PM #1
My experience is in overhauling a 16" truss dob that was about 20 years old. It was pretty typical for the time.
It had a large mirror box, small rings and an upper cage that was a bit heavy. It also had about 20 pounds of counterweights.
I think that some extra weight in the bottom won't hurt. The upper cage seems to be the place where weight really causes trouble.
With a light mirror I think that a light cell will mean you need to have the balance point rather far forward. This would result in a high rocker box and a large mirror box and greater overall weight. Or you will end up with a lot of counterweights.
Draw up (even by hand on paper) a fairly detailed plan of the tube assembly. Put in some measurements and weights. Then use a spreadsheet to calculate the balance point. I suspect that the balance point will be far forward of where you expect if you assume a very light mirror and cell.
Then vary the weights a bit to determine how the balance point moves around with changes in weight.
I think heroic efforts are justified at times to lighten the upper end. I think that too much focus on the lower end weight will just cause trouble.
This all assumes a typical "Kriege style" design. If you are building a single ring upper end, then you may want a very light cell.
Let us know how this all turns out.
