I currently have a rather large set of calouses (sp?) on my hands that speak to my current experience in this area.
Typically when you hear the expression "turned edge" the speaker really means "turned down edge" (TDE). An edge can also be turned up, but this is less common and much easier to fix. For this reason TUE is almost never observed on finished mirrors. The paragraph below refers primarily to TDE.
When making a mirror the first step is to give the surface of the mirror a spherical shape. This can be done to arbitrary precision by grinding the glass against another surface in a random manner. Once a spherical shape is achieved, the figure is tweaked to make it paraboloidal. TDE usually originates prior to parabolizing. Because the glass at the edge is relatively unprotected by neighboring glass, it is easy to grind it off much faster than the rest of the surface. This can happen due to improper grinding technique, differential heating of the glass, or pitch that is too soft (pitch is the stuff used to polish and figure the mirror.) Once the glass at the edge of the mirror has been removed, it is impossible to replace it, so the only cure for TDE is to grind down the rest of the mirror to match the edge. This is very time consuming (did I mention my sore wrists?) Often mirror makers will ignore (pretend not to notice) the turned edge and proceed the figure the mirror anyhow. The result is the edge does not focus light at the same place as the rest of the mirror and contrast is reduced.
