I'm sure these ideas have been tried, just wondering why they aren't more common or if anyone on this forum has made a mount like one of these. Both mounts fall into the category of ultraportable equatorials for visual use and as such are alternatives to a GEM (too heavy) or alt-az (hard to track at high power). I envision a small refractor on the mount (could work for newts as well, though the benefits would be questionable).
Mount 1: A fork mount for small refractors: Same construction as any other fork mount, but the fork is not long enough for the OTA to swing far past the zenith towards north. This could be just as simple and lightweight as the popular alt-az mounts for refractors, but could be used by anyone in mid-to-high latitudes to equatorially track planets along the ecliptic. In order to view anything in the northern sky, the mount must be turned around and used as though it was an alt-az. The whole scope and tripod could turn, or a third, simple azimuth axis could be added for this. This seems like a very simple thing to build -- why haven't I seen it before.
Mount 2: A 3 axis mount. The first 2 axes would be in the form of a mount like the Unistar. Below the Unistar-like mount is a third axis that provides an hour or 2 of tracking. This is essentially just like a Dob on a EQ platform, but much, much smaller. A company called Optical Research (or something like that) made a mount like this for a newtonian. The drawbacks would be that the mount is latitude specific and can only track for a limited amount of time before being reset.
Can anyone give an example of a mount built like one of the above?
--Ian
--Ian
