james carter
North American Nebula NGC7000
Will I need to move my Spider?
Started by Gregoire, 08/11/2005 11:53PM
Posted 08/11/2005 11:53PM Opening Post
Hello All,
I'm putting the finishing touches on my 1st telescope, an 8" f6 reflector and I installed the spider and secondary to see that holes were drilled in the right spot and to begin to determine where the primary needs to be installed.
Anyhow, looking down the focuser, without an eyepiece, I dialed in the open end of the tube and aligned things as well as I could. The mirror looks to be centered top / bottom, but the side to side it seems like the mirror is 1/8" too further toward the primary than toward the front of the scope. Unfortunatelly there doesn't seem to be an more adjustment available to draw it toward the front of the tube. Am I gonna need to redrill holes or am I obsessing for nothing. Knowing very little about telescopes, I'm clueless as to how much of the secondary is actually used. FWIW the secondary is 1.6" on the minor axis. Is there a sweet spot that allows for some forgiveness?
Greg
Posted 08/12/2005 12:22AM | Edited 08/12/2005 12:23AM #1
The secondary mirror, as viewed down the open focuser, should appear to be round and fit the focuser hole if your head is held at the right distance. The mirror should be centered in the focuser tube as well so the focuser tube walls look the same all around.
If you see the secondary as a round circle, but it appears to be cut off at the primary side, then it is too far toward the primary. We are talking the secondary mirror reflection and not the primary mirror reflection in the secondary, OK?
If this is the case, then it should be moved toward the open end of the scope away from the primary. If you don't have any more threads to raise the mirror, is there a nut between the secondary holder and the spider that might be removed and place on the other side of the spider?
Now if you are saying that the reflection of the primary in the secondary appears to be to below the focuser, that is another story.
Let me know which is the case.
http://www.fpi-protostar.com/collim.htm
Take a look at this link, it shows a great pictorial guide for this setup.
Posted 08/12/2005 12:51AM #2
Redrill and plug the old holes with plastic plug with waterproof glue. Move it about 3/8" or 1/2" to give yourself some slop.
Ed
Posted 08/12/2005 05:09AM #3
Hello:
In my opinion,you should not need to drill any new holes. You should be able to shim the focuser so that the focuser is pointing at your secondary. Your focuser doesn't *need* to be square to the tube for the scope to work well. I believe, and I may be incorrect on this, that laser collimators require that the light path make a right angle on the secondary. If so, then shiming the focuser would negate the usefulness of a laser collimator, but you would still be able use a regular collimator like a Cheshire eyepeice. When I built my dobsonian, I basically paid no attention to the angle of the focuser relative to the tube axis. I just made sure it was about the same place along the tube as the secondary and tilted the focuser to point at the secondary, and all is well. For an offset as small as yours, it should be possible to collimate the scope by tilting the secondary until the center dot on the primary is aligned with the cross hairs on a Cheshire collimator, but there may be some light lost. It's probably easier to just shim the focuser, then you don't have to worry about losing light.
Cheers
Mike Connelley
