VDB 142 Elephant Trunk HOO
wood protection
Started by ziff, 04/03/2008 09:44AM
Posted 04/03/2008 09:44AM | Edited 04/03/2008 09:54AM Opening Post
anyone know if a dark stain is more protective (uv, moisture, etc)than a light wood stain? I am thinking about just possible using polyurethane to protect my scope thAT I'M making but if it does not protect as well as a light stain and a urethane then I will use a dark stain and polyurethane.
Posted 04/03/2008 10:19AM #1
The stain color has nothing to do with protecting the wood. If you must stain, use 2 coats of a spar urethane over the stain. Spar urethane has the UV protectors in it. Good Luck!
Posted 04/03/2008 02:45PM #2
Stain with a lot of pigment [rather than dye] would afford some protection. That's why paint is more effective than stain at protecting wood.
Look for Cetol wood finishes, they're the best clear wood finishes you can get for exterior use.
James Adams
Posted 04/05/2008 01:27AM #3
Bill,
I've been wood working for a very long time. One of the best companies for finishes is General Finish. You can find them at Rockler or Woodcraft. They make an excellent outdoor varnish that is water based and has good UV protection. It's very easy to apply and work with and General Finishes are outstanding. General Finishes’ Exterior 450 is the varnish I recommend. You will be very happy with it. They also make some oil-based products if you prefer. If you are close to a Rockler woodworking store or Woodcraft I would recommend going in a talking to their finish expert. Good luck!
Posted 04/05/2008 02:09AM | Edited 04/05/2008 02:10AM #4
Bill,
What species did you use for your project?
Bruce
