Lost in the long thread below, Vlad and Mike and Newt helped me conclude that somewhere between 2.3 and 2.7 min axis for my secondary was appropriate:
"If you'd take H=0.25"+1.45"+1.5"=3.2", then your diagonal-to-focus distance would be L=T/2+H=7"+3.2"=10.2". Your min diagonal minor axis is A=L/f#=10.2"/4.46=2.3". For 0.5" (~0.5 degree here) fully illuminated field you'd need
A=2.3"+0.5"(1-L/F)= 2.7" minor axis. Illumination 14mm
off-axis is 82%, and 63% 23mm off-axis. Not much different from what you came up with. Take your pick. "
Well, I did take my pick. It took me a couple days to think through this analysis, but I see it is all correct now. One thing though, is this is all theory. In practice one doesn't find an infinite choice of secondaries. And I found at my local astronomy shop a really nice holder and spider set up for a 2.55" secondary (which they also supply). A quick calculation at the shop showed that this was a 19.5% CO by diameter which is good in my books, not too little going on some wild planetary optimization goose chase, not too much as to turn my newt into a low-contrast SCT with diffraction spikes.
So in the real world I found and bought this nice, light totally suitable for my build 2.55" holder and mirror. So now I know that fits in that range Vlad (and Mike and Newt) helped calculate. But seeing Vlad's response to John Bambury one thread below made me wonder if 2.55 is close to my theoretical minium of 2.3 I don't want to see the edges of the diagonal (of course you could paint or tape them over as a last resort), but right now I have a freedom which John doesn't: I am designing and can make my cage diameter anything I want, whereas he is stuck with his tube as is.
I can also position my cage vertically anwhere. So, Vlad, Mike or anyone else care to give me a yea or nay on this one:
Given a 13.1" D and FL of 58.5" f/4.46 and diagonal (real) of 2.55" and focuser hole of 2"
what should be my ID of my upper cage assuming that I am not doing any secondary offset, just a centered secondary. I was thinking 14" with a .25" focuser board. Still sound good? I was also thinking of making a 1/4" filter slide with the one 2" hole being filter free which would be on the inside of the ID and could act as a baffle if that is a consideration?
Thank you (all) !!!! You're so helpful!
Tom L
Tom L
