Alex Andreani said:
The drive does not seem 2 work, tiny buzz and little movement when E. & W buttons r pressed.
Is the motor supposed 2 run the entire time the buttons r pressed?
Stupid nubie question # 2,
When I turn on the tracking drive on the motor is also supposed to run right, can u usually hear this drive run.
Can I get parts to fix drive, if so, where do I get them?
Are you sure the drive is not working? It's not called a clock drive for nothing. The buttons will make SMALL changes to its speed for photographic guiding; they will NOT zip it across the sky. If you want to check it inside, turn on the drive and let it run for an hour or so.
With the drive on, you may hear a slight hum.
Likely there is nothing wrong with it.
Uncle Rod
Time on your hands?
