From the
ATWB Customer Gallery
Andromeda Galaxy M31
Poll
2020 President - NO COMMENTS (take to Politics Forum)
Results
Previous Polls
searching for a meade lx 200 motherboard
Started by GMTCMB, 03/04/2017 06:12AM
Posted 03/04/2017 06:12AM Opening Post
My mount has stopped working and I am in search of help. I know inside its a 1993 setup. I replaced the power supply which I didn't think was a problem but still not working. I am looking to buy a new board and if someone could point me in the right direction I would be grateful.Can't sell a scope and mount if mount doesn't work.
GMTCMB's attachment for post 60818
Posted 03/05/2017 03:53PM #1
George:
I can't help with a new board, but if you're handy with soldering, you could open the case and replace the tantalum capacitors in the power sections. They are infamous for going bad and I repaired two mounts with the same problem. If you do so, use 35 to 50 volt caps in place of the ones you removed. Also check if there are any fuses inside which may have burned out.
George
