starhopper 12 on Eq platform w (Mods)
Started by geobike, 02/16/2006 11:28PM
Posted 02/16/2006 11:28PM | Edited 02/16/2006 11:37PM Opening Post
Hi all,
I recently was given a Starhopper 12 as a gift from my wife and daughters. The telescope gives great views but has a lot of short comings in the mount.As another Starhopper owner, Pat wrote in another thread, when tightening the altitude tension knob the inserts in the plastic bearings come out. I disassembled the scope and put nuts and washers behind the bearings and replaced the standard knobs with larger threaded machine knobs. This fixed that problem. Then I wanted to add tracking so I built a eq. platform. Next I found that when trying to take pictures of the planets the azimuth bearing would not stay in place. Because of the radial roller bearings the mount would want to "drop" into the spaces between the bearings. I replaced the the bearing with 3 furniture moving pads and used one of the original metal bearing faces as a friction surface. Now I can control the position and tension in Azmuith much eaisier. Pat told me about setting circles he made for his Starhopper so I tried them on Mine. I first set the Eq.platform to level using a bubble level then using a shareware program called Cartes du Ciel I get the alt-az coordinates and dial in the object. Then I can track for 20min if I choose. Another plus to this set up is I can polar align the platform using circles. I first level the ground board to get proper height of the polar axis and then use a compass to get approximate north. Then with eq. platform level I sight on a object such as moon or whatever. I look up coordinates in my program and check the azmuith readings on scope. Since the Azmuith circle is fixed to the base if the reading does not agree with the program value I turn base board and resight with scope until the two readings agree. By doing this I get a fairly accurate polar alignment. (thanks for the help with the circles Pat) smile. Now Im experimenting with digital camera pictures with my point and shoot camera Cybershot dsc-p71. Celestron really needs to take a second look at the Starhoppers mount. Otherwise this scope gives great views for a decent price.
George
geobike's attachment for post 29821
Posted 02/17/2006 12:58AM #1
Very nice, did you make the EQ Platform?
Posted 02/19/2006 07:08PM #2
Very nice, can you give me the link where you got the plans?
Thanks, Daren smile
