Tumbling Iridium’s and Geodetic flashers satellites are very cool to track and watch.
I use Brents software for the tracking of satellites with my LX200GPS 12", his software is found here:
http://www.heavenscape.com/ (its $26 and demo is for 20 tries)
I started tracking the Iridium's satellites for their flares, and then I found http://www.calsky.com that predicts tumbling out of control Iridium satellites. These give a nice show comparatively to plain old satellites.
Just set your coordinates and user level to Astronomer, and then go to satellites (top right), then tumbling satellites, a list will popup. Many options from here, I sometimes just print the list so I have the predicted tumblers.
I then use TLERetriever http://www.celestrak.com/SpaceTrack/TLERetrieverHelp.asp to get my TLE's (sometimes space-track.org does not work properly though Sat-Tracker). Or you could manually get them from Celestrack (no signup req) http://www.celestrak.com/NORAD/elements/master.asp or
http://www.celestrak.com/NORAD/elements/ , or
http://www.space-track.org/perl/login.pl
I usually get the master list (everything), visual, iridium's, and geodetic TLE data sets (it's 2 clicks with TLERetiever once its setup, uncompresses them too). With my printed list of tumblers and the predicted times, I load the iridium's TLE data and turn all filters off in Sat Tracker, this shows all ~90 Iridium satellites. I then find the 1st tumbling satellite on my printed list coming up and popup the world map. Then click track when the sat is with in view.
Another of my favorite satellites is EGP (USSPACECOM 16908). This is a geodetic satellite that flashes with irregular pulses, very nice. Another flashing sat I just found is Cosmos 1275 (USSPACECOM 12504).
Its easy to make custom TLE lists, I do this if I have time, open up the master TLE list, then open up notepad in another window, so that both windows are visible, then in the master TLE window do a CTRL+F (opens find window), search for your satellite, highlight the 3 lines and copy and paste into the blank notepad window, make sure you have no extra spaces and a "return" after each satellite TLE data, like this (this data is new as of 5-21-07)
EGP
1 16908U 86061A 07141.55467202 -.00000083 00000-0 10000-3 0 3012
2 16908 50.0094 328.4652 0011610 89.1018 271.1148 12.44457504613268
ISS (ZARYA)
1 25544U 98067A 07142.09522727 .00017649 00000-0 10453-3 0 2499
2 25544 051.6334 238.7303 0008905 212.6251 208.5074 15.78137819486656
Another site worth mentioning: http://www.heavens-above.com
I do this satellite tracking stuff for 60-90 min starting at sundown, then switch over to the good stuff
Have fun, clear skys!
Oz
PS a plain old Iridium flare from my backyard is attached.
EGP
ISS (ZARYA)
Oz
