I`m beginning with a good scope and need some input.
WHAT WOULD BE THE IDEAL CCD IMAGER FOR A MEADE 14"
Started by gliders, 10/16/2005 01:49AM
Posted 10/16/2005 01:49AM
Opening Post
Posted 10/16/2005 11:40AM
#1
Hi:
1. Chris says, "What's your budget." $10,000 will buy a pretty decent camera from SBig or Finger Lakes. Quality CCD imagers are not cheap, if you are used to thinking in terms of 5 megapixels for $400, the prices will surprise you.
There are several reasons for this, limited production is one. But there are others. The cooling of the CCD chip to reduce the noise is complicated and requires sealing the chip for from the atmosphere.
Another biggie is the quality of the chip. Chips in consumer cameras have defects which are handled by the firmware in the camera. Chips in quality CCD camera might have started out in the same batch but has been selected because it is a class 1 or 2 chip with very few defective pixels, maybe none. This costs.
2. What do you want to image? The size of the pixels and the number of pixels determines the field of view that you can image. The 14inch RX-400 has a focal length of about 3200mm. If I assume that you want 1 arcsecond resolution per pixel, that's pretty requires very good tracking, then you will need a camera with 16 micron pixels, moderately large and more costly. With a camera with a 1000x1000 chip, you would have a field of view of about 1/4 of a degree, about half the size of the moon.
As Chris said... What's your budget?
Funding Member
Sponsors
- BW
- BBLABS LLC
- OMI OPTICS USA LLC
- CarbonScopeTubes LLC
- Astromart Customer Service
- Anacortes Telescope
- APM-Telescopes
- RemoteSkies.net
- Matsumoto Company
- kwtelescope
- AstroMart LLC
- FocusKnobs
- Waite Research
- Desert Sky Astro Products
- astronomy-shoppe
- Vernonscope
- SellTelescopes.com
View all sponsors
