I know if you look I have more questions then anyone you have probably ever seen. First time i took my 114mm 910mm retractor out i put the Meade 3x Barlow in and when i viewed the object in this case a planet i could see the secondary mirror mount ? is this normal even if I might of had to much power ? I need to buy a book or something if my questions are to stupid or you get tired of me sending so many let me know I wouldn't want to inconvenience anyone.
3x barlow i can see the secondary mirror ?
Started by Dimpa, 03/04/2006 06:03AM
Posted 03/04/2006 06:03AM
Opening Post
Posted 03/04/2006 10:01AM
#1
My guess is that you are not in focus so that what you are seeing is the out of focus pattern of the planet with the shadow of the secondary mount.
As far as asking questions, please do. Not only will your question be answered for you but others will learn from your questions as well.
A couple of comments:
Often manufacturers ship barlows and eyepieces that are pretty poor and so exceed the capabilities of the optics. They do this so they can advertise high magnifications that are virtually impossible, even in a much larger scope. The 3x barlows I have seen shipped with 114mm reflectors are plastic and are not so bad but only useable with the lowest power eyepiece.
The optics themselves of the 114mm x 910mm Newtonians are generally quite good, no real upgrades necessary. As others have pointed out, if you want to improve the views, better eyepieces would be a first step. Often there are good quality used eyepieces that would be a real improvement for $10-$20 here on Astromart. Plossls are good...
What eyepieces do you have???
jon
jon
Funding Member
Sponsors
- RemoteSkies.net
- FocusKnobs
- Astromart Customer Service
- AstroMart LLC
- Waite Research
- APM-Telescopes
- astronomy-shoppe
- BBLABS LLC
- Desert Sky Astro Products
- Vernonscope
- Anacortes Telescope
- CarbonScopeTubes LLC
- SellTelescopes.com
- kwtelescope
- BW
- OMI OPTICS USA LLC
- Matsumoto Company
View all sponsors
