Aperture, aperture, 80mm?
Started by BoyntonStu, 03/29/2006 01:13PM
Posted 03/29/2006 01:13PM | Edited 03/29/2006 01:14PM Opening Post
Why are 80mm apo scopes so popular?
If aperture is king, why not use a 120mm achromat at low power and stop it down to say 90mm for higher power?
Are apos at 80mm so good that aperture does not rule?
What am I missing?
Posted 03/29/2006 02:38PM #1
1. Wide-field Photography. APOs rule here.
2. Extreme portability. Airline portable, in fact.
3. Lust factor.
I'm sure there are others. And your example of a 90mm achromat will not perform as well as an 80mm Apo at high powers on planets, etc.
Posted 03/29/2006 11:24PM #2
I am fairly new to telescope astronomy,having used scopes now for just over a year. I was a pure visual stargazer for years, a short stint with binos then back to eyes.
I started with an 8 dob and a 6 Eq mounted hardin Newt, then moved to a 102mm Orion mak on a camera tripod. Next came a Tele vue Pronto.
All had good and bad points, I found that the pronto was the scope I used most often and recived the most joy from. Its only fault was its size ( too small)!.
So moving up to an 80mm Ed scope as a main scope has been the perfect choice for me. Easy to set up,affordable, and great views of wide swaths of sky.
I do plan on picking up another scope or two and am currently looking for a smaller Newt and later a nice 4 inch apo for planets.
What I know, the public does not approve, and what is approved, I know to be error.
N.C.
