Barlows and eyepieces
Started by kd4avp_1, 09/03/2005 02:29AM
Posted 09/03/2005 02:29AM Opening Post
Having purchased my first Dob and getting familiar with it, I am beginning to plan my eyepiece purchases. I bought a 3x barlow and have used this with my 25mm and 10mm EP. With the 25mm I could see much better than the 10mm. Actually the 10mm was almost useless. I am using an Orion XT8 with 1.25" EP. I want EP's that give me more veiwing area. The 10mm just seemed too "tight" to look thru. Maybe its me and the small hole in the EP.
Would love some suggestions on 1 or 2 good EP's to purchase and have in the case. Also need a moon filter...or do i?
Thanks in advance for any and all advice!
Keith
Posted 09/03/2005 06:02AM #1
Well, I am going to assume you don't want to spend more on a couple fancy designer label eyepieces than your telescope cost. Personally, I own the complete set of Edmund "RKE" eyepieces, plus a couple of Celestrons and Orions. I would recommend something in the 28mm to 35mm focal length range for
a low power/wider angle field of view. For a "moon" filter I prefer a "ND 25" and stacking a color filter.
wdnstars
Posted 09/03/2005 08:20PM #2
Excellent advice from all. Thank you for your input. You have helped me fill in the blanks nicely. I think if I can find a few good EP's to fill between the ones I have, I will enjoy my scope even more.
The fall and winter nights are going to be much more enjoyable now!
Keith
