crosshair eyepiece
Started by sebrin, 01/16/2007 01:39AM
Posted 01/16/2007 01:39AM Opening Post
I'd like to add crosshairs to a 25mm Kellner eyepiece, for use in an 80mm finder scope. What's a good way to do it?
Thanks, Sebrin
Posted 01/16/2007 03:39AM #1
I've done this on a couple of eyepieces. I guess the answer is "carefully!" The first trick is to find some really thin wire. The best I've found came from an Astromart contact, and he got it from a tiny transformer like those found in a microphone. Others have suggested using human hair (or even spider webs!), but I opted for the more conventional copper wire solution.
The next trick is to find the right depth in the barrel to mount the cross hairs. It should be at the field stop if you have one. If not, try moving a bent toothpick in and out to see where it focuses when you look through the eyepiece.
I then used a circle template to make little pencil marks at 90 degree intervals. Using Crazy glue, anchor one end of the wire to the field stop at one of the pencil marks and let it dry overnight. Then stretch the wire across the barrel to the other side with a scrap of cardboard, and glue it. Repeat for the crossing wire, and you have it!
The 25mm Kellner is a pretty standard finder eyepiece. If you want to double your field of view, you might try a 32mm plossl instead to get the maximum field of view in a 1.25" barrel. I saw one on Astromart yesterday for only $16!
Hugh Bartlett
Posted 01/16/2007 04:42PM #2
sebrin campbell said: I'd like to add crosshairs to a 25mm Kellner eyepiece, for use in an 80mm finder scope. What's a good way to do it?
Sebrin: A few years ago I purchased an adapter on Astromart that adds a cross reticle to any 1ΒΌ-inch eyepiece whose focal length is reasonably long -- like 25 mm -- and which simply screws into the base of the eyepiece like a filter. I believe the seller was Mike Spicer in Canada, but unfortunately his ad indicated that there were only a few left and perhaps he's no longer making them. I mention this in response to your inquiry in case you were interested in doing some research to find out if such an adapter is available anywhere.
Posted 01/16/2007 05:47PM #3
I have made them with human hair and wire. Human hair is where the name crosshairs came from, they used womens hair in WW2 to make the bomb sites.
I have used a crush washer of aluminum or a composite material that I found at the hardware store. They are used to seal plugs, like oil pans on cars and stuff. I would get one that just fit the inside of the barrel and then push it to the field stop or with some EPs, just unscrew the barrel, place the ring in and screw the barrel back on the body. With this type arrangement I selected a ring that was the same size as the barrel so it would fit an be held in place by the barrel.
Then I would print this picture and tape the ring to the reticle with the ring centered well. Next I would place a hair or wire at one side on a cross line and tape it, then stretch the hair across to the other side, align and tape it to the paper. Repeat this for the other hair and then using Superglue I would place a small amount where the hairs touched the ring. Let this dry, then cut the excess hair off and you have a perfect crosshair.
fblue's attachment for post 110829
Posted 01/17/2007 02:46PM #4
Thanks, Sebrin
If you want to buy one, Paul Rini makes some inexpensive eyepieces with cross hairs. These days his stuff is sold by Bill Vorce at the www.telescope-warehouse.com
Try emailing Bill and see what he has, I think they are around $25.
jon
