DSLR mount to Newtonian?
Started by johngswimming, 09/04/2005 08:32PM
Posted 09/04/2005 08:32PM Opening Post
After having done standard google searches for this topic I still am unsure about how to practically mount a DSLR to a Newtonian scope. If anyone is aware of any resources that they could direct me to I would very much appreciate it.
Thank you.
JB
Posted 09/04/2005 09:59PM #1
T rings and adapters for your specific brand DSLR will get it done. Search on the Anacortes web site for T ring, T-ring, adapters, your brand of telescope, your brand of DSLR. That should get you to what you seek. Also, open the sponsor links and view what they have available. As I recall a few may have what you need or the ability to custom manufacture it for you.
Kent
Posted 09/04/2005 11:02PM #2
Hi:
There are several ways to attach a DSLR to a Newtonian, it depends on what exactly you want to do. It also depends upon the Newtonian and the mount.
First some questions:
1. Do you have an EQ mount?
2. What sort of focuser do you have on the scope? What is the scope in question?
Some random comments:
1. IF you want to do "Prime focus" photography, ie use the Scope as a lens with no other lens on the camera there are likely problems, mainly most Newtonians do not have enough "in focus travel" to allow a SLR or DSLR to reach focus. Older scopes sometimes had two sets of holes which would allow the primary mirror to be moved forward but today it is somewhat uncommon.
2. If you want to do Afocal photography, ie use an eyepiece on the telescope and another lens on the camera, then there are a variety of ways to do this. Probably your best bet is www.scopetronix.com, they seem to specialize in mating digital cameras to telescopes.
3. If you want to piggy back the camera on the scope, essentially just using the scope as way to attach the camera to the mount, then many mounting rings have a 1/4-20 stud that an be used to carry the camera.
Astrophotography is not a simple task if you want to take long exposure photos. Accurate tracking is critical and tedious, to get a mount that is solid and tracks accurately is more important than having a fancy camera or telescope, a good rig starts at the ground and works it way up.
check out www.astropix.com . Some nice essays and tutorials there as well as some nice photos.
jon
