Sculptor Galaxy (NGC 253)
German equatorial mount weight capacity
Started by arkansas_firefighter, 05/13/2005 10:01PM
Posted 05/13/2005 10:01PM Opening Post
When comparing the weight bearing capacity of equatorial mounts, do you use the combined instrument and counterweights, or just go by the instrument weight alone ??
Posted 05/13/2005 10:48PM | Edited 05/13/2005 10:49PM #1
The rating for a given mount does not include the counterweights. However, be aware that it includes more than the optical tube. You will also be putting finders, diagonals, and maybe a camera on it. They count as the load also. Secondly, the manufacturers get to make up their own numbers. WHat they rate the mount as may be liberal or conservative. (It will rarely be less than the mount can actually hold.) At any rate, there is no standard for what the rating is, and therefore the buyer must beware when comparing measurements from one manufacturer to another. And Finally, your demands may not be the same as their rating system. A mount that is to be used for astrophotography should have "excess capacity."
