Hi all.
Well, I'm looking for a new setup....something in between my Stellarvue 80/9D and Discovery 12.5" DOB, and have a question about setup time for a fancy mount.
I live under fairly clear skies most of the time (I can often see a hint of the Milky Way when there's no moon) and like to run outside and take a quick look around. The Stellarvue has been nice for planets, the moon and the Orion Nebula, but I want to see more. The DOB is too much to lug outside when I've only got 10-20 minutes. I was thinking of a used, medium sized (maybe 6"-8") Newtonian on an Alt/Az mount, but decent mounts for a 25lb. Newt seem pretty expensive.
So, the next possibility is buying the whole setup, which pretty much means a Go To mount like the Meade LXD75. I believe these are OK mounts, but I wonder if I'll spend my 20 minutes of free time just getting set up.
Does anyone have thoughts on how much time to budget to get up and running each night with one of these setups? And can you point them by hand, or must you use the controller?
Thanks, Greg
Thanks, Greg
