How to focus a Canon 20D DSLR?
Started by dacop, 03/04/2005 06:18AM
Posted 03/04/2005 06:18AM Opening Post
ok...my question is simple...I hope.
I recently purchased a Variable-Projection Camera Adapter and a T-Mount for my Meade Tele and Canon 20D. My question is, since the 20D does not offer an LCD to see what I am photographing, only a typical SLR view finder, how do I know if the subject is in focus if I cant see anything? Or how do I even know if the subjest is still even in the eyepiece, which most of the time it is not. Is there a trick or procedure I am missing? Or do I have to keep moving the scope around and hope I get lucky in finding the subject again by shapping pictures? Any help would be greatly appreciated.
Dan
Posted 03/04/2005 12:57PM #1
Dan:
Focusing is one of the biggest difficulties in taking astrophotos. Lots of techniques and tools you can make or purchase. There is no easy solution. A dedicated CCD camera will have a focus mode that allows you to adjust the focus and then see the results in a few seconds on the computer screen. This is pretty slick but otherwise its not that easy.
My suggestion is to take some time and learn what you are doing step by step.
Astrophotography is not easy or simple but if you start with the basics, ie fixed tripod shots then piggybacking and then moving on to prime focus, you will develop the skills to know how to polar align your scope properly, how to judge exposures, how to focus, how to find the targets, how to guide....
Check out www.astropix.com The essays on Astrophotography are filled with good information and techniques.
This stuff is not easy, the only short cuts are to spend large sums of money on fancy mounts and fancy cameras with autoguiding and all that stuff built in.
Focusing? trial and error....
If the target is in the FOV?? The mount needs to be sufficiently well aligned and the tracking needs to be sufficiently good that it will not move.
Jon Isaacs
Posted 03/04/2005 09:22PM #2
I want to thank everyone for their input, I guess it will just take a lot of practice. I was able to pull out my scope and camera today and practice in day light on street objects. I had much better success then last night in the dark. I should have done this before attempting night shots, this helped me get to know my scope and camera a little better.
