Well the other night I collimated my new LXD75 SN-10. But I had this feeling that I should have had better resolution on M31 even though I was in a light polluted suburb. I was using a UHC filter, I just had this naggin feeling that the collimation was off. I followed the laser instructions I found on-line. I didn't do a star test I know I should have but hear me out.
1. Place the laser in the focuser.
2. Adjust the secondary mirror to center the laser dot on the primary.
3. Then adjust the primary to refocus the laser dot back into the origin hole.
Took no time.
So I was reading up and throughly confusing myself on how to properly collimate this beast being that it has a fast focal ratio f/4 I understand that it's sensitive to collimation being a little off.
So I figured I fire the laser through it again. The dot is centered on the primary mirror but If I rotate the laser collimator 180deg the dot is no longer centered. BLAH.. So I'm not sure what to do. If I line it up this way it will be out of alignment 180deg the other way. I really don't think there is a way to correctly decide. The collimator should always center the dot regardless of rotation correct???
Chris
Took no time.
Chris
