Need suggestions for grab-n-go mount
Started by GLangmead, 03/13/2006 04:40AM
Posted 03/13/2006 04:40AM | Edited 03/13/2006 04:41AM Opening Post
I took the plunge and bought a scope after 4 wishy-washy months of deciding. I bought a William Optics Megrez 80 II ED here on AM, because I want grab-n-go and portability.
Now I need a mount. The computer nerd in me wants a CG-5 goto mount, but that violates my grab-n-go approach. I can get that later -- for now, I want a good inexpensive simple mount. If it can be brought as carry-on luggage, that's a plus because I could bring it when we visit my mother-in-law in rural TX. I looked at the Orion AZ-3 and EQ-1, and I like the idea of slow-mo controls. I can't tell if they will collapse to a small size, and I'm sure there are other models I haven't heard of. Any advice?
Greg
Posted 03/13/2006 06:45AM #1
I second Peter's suggestion. Very smooth (you won't miss the slow motion controls) and very stable. I have one for a 4" refractor and love it!
Hugh Bartlett
Posted 03/13/2006 03:02PM #2
Greg:
You have gotten several good suggestions, I will add my own favorite. First a few comments:
I believe that a mount should be balanced, either by counter weights like EQ mounts are, or by the telescope itself as DOBs and fork mounted scopes are.
Camera tripods and mounts like the AZ-3 place the scope on top of the mount. This is fine as long as you are viewing horizonally but as soon as you start to look up the scope tries to flip over backwards and it takes some real force to lock it in place.
If the center pivot of the altitude axis passes through the center of gravity for the scope, then it can be placed in any position without it moving. Mounts like TeleVue Telepod and I believe the UA mount pictured previously work this way.
My personal favorite is to use a small EQ mount as an ALT-AZ mount. All that is necessary is to point the Polar Axis (the one you point at the north pole) to the zenith. If you have tube rings, then you can balance the scope front to back and you are done.
The advantage of this scheme is that you have both the smooth and easy pointing of the Telepod type mounts and very nice Slo-Mo controls that were the RA and Dec controls. One merely points the scope at the target and then begins manually tracking with the Slo-Mo controls.
Currently I am using an old Meade 4500 mount for this, the EQ-2 and EQ-1 also will work but have tangent arms on the Dec axis rather than the full circle gear of the Meade mount so the altitude axis can require resetting it. I do not use the counter weight with mine, I have not had a balance problem in this way but it does need to be watch.
Currently I am using this mount with both an ED-80 and a Burgess-Orion (Burion)100F6 and use it up to the maximum of 250x with both scopes and it is stable and smooth. I have attached a photo of the Burion mounted ALT-AZ on an EQ mount.
One could do this with the EQ-1 but I think it would work better with the EQ-2. I am fairly sure it works with the Vixen Polaris but those are not so inexpensive.
As I said, there are other options, this one works for me.
PS. My other favorite is to mount the scope "side saddle" on a BOgen 3047 head but thats a whole 'nother story that will have to wait..
jonisaacs's attachment for post 101834
Posted 03/14/2006 05:22PM #3
I too am considering a nice mount for terrestrial and astro viewing for my 85mm SV.
I find the price of the UA Unistar a bit more than the Vixen Porta Mount which also includes a tripod!
Let's see:
UniMount Light Deluxe No tripod $429.00
Vixen Porta Mount W/tripod $450.00
The Vixen looks like a better deal if the tripod is any good.
