Below is a diagram I’ve created to illustrate the oppositions of Mars from 2003 through 2018. An opposition occurs when as viewed from Earth another planet appears to be located opposite from the Sun.
Seen are the orbits of Earth and Mars with indications of the perihelion and aphelion points. The sizes of the bodies are not to scale, although the orbits are. The compass indicates directions in ecliptical longitude. AU refers to the distances between Earth and Mars in astronomical units (1 AU is the average distance between Earth and Sun).
The synodic period for Earth to lap Mars in their race around the Sun averages 2.135 years. That means that the Earth orbits the Sun an average of 2.135 times for each 1.135 times that Mars does so. So oppositions of Mars from the Sun are separated by an average of 2.135 years. In actual cases these figures can vary significantly from the averages.
The orbit of Mars is considerably more eccentric than that of Earth. Perihelic oppositions (when Mars is near its perihelion) are the ideal ones and occur at intervals of 15 or 17 years. The opposition of 2003 was especially close: the best in more than 50,000 years and until 2287. The next perihelic opposition will occur in 2018, although Mars will be 3% further away than in 2003.
The next opposition of any type will occur on 2007 DEC 24. Mars will be 53% further away than at the perihelic opposition of 2003, but 13% closer than at the aphelic opposition of 2012.
For astronomical graphics, including
monthly wallpaper calendar, visit:
CurtRenz.com/astronomical
Curt Renz
