Perhaps I did it wrong? 4.5" viewing very limited.
Started by JesterDev, 06/20/2006 08:29AM
Posted 06/20/2006 08:29AM Opening Post
The first mistake I made (a mistake so far anyway) was buy a used Meade 114EQ-DH4 Equatorial Starfinder. This was only my second telescope ever, the first one was back in '81. I didn't know that it was a department store scope, and well I figured for $80 it seems like a good deal. I wont go into detail about how I had to repair a few parts, nothing major, just some cracked plastic, and the drive motor. Anyway to the point; I took it out tonight and expected to see at least some detail, but all I saw was what I think was a planet which had 3 moons (?) off towards the south I believe. Not even sure, but it was the brightest star in the sky, at least that I could see with all the city lights. The supposed planet was about the size of the end of a cigarette butt (sorry, that all I can think of that size) and the supposed 3 moons where about the size of a pin. I'm thinking that the moons where nothing more then a reflection, but then again you never know. Seems to me I could have bought a cheaper department store scope and pretty much seen that same thing. So here I am asking others if perhaps I was using the scope wrong? I used a H25mm eyepiece, and then tried a H12.5mm which seemed to work slightly better, and the SR4mm didn't show a single thing.
So it seems that though I am using it wrong. The manual says that I should be able to see things, that I did not see at all. I am rather discouraged so far, but it was my first try. But I can't help but think about what little I could see. To be perfectly honest it was just like getting a minor close up of the stars. I scanned nearly the entire sky, and other then that supposed planet, I saw nothing at all other then stars.
I have read that I need to buy better eyepieces then the ones that came with it, but I figured with these I would be ok for now and don't think that things will improve all that much over what I already see.
Another thing, if anyone has any advice additional to the above, the gears(?) to not turn at all, even with the motor turned on. Any idea's what could be wrong?
So anyway, if I can't get this going after a few weeks, I don't think I will be buying (rather making) an 8" Dob..
Any advice is greatly appreciated.
Posted 06/20/2006 12:43PM #1
MichaelL
Hello and Welcome to Astromart.
Some thoughts/suggestions:
1. Indeed it was Jupiter you were looking at, three moons were visable, the fourth, Europa, was behind Jupiter. I enjoy watching Jupiter, the cloud belts change, it is quite amazing how quickly they move. The moons change noticeably over the course of the evening and at times even minute by minute. Most exciting for me are the shadow transits, under decent conditions, one can see the shadow of one of Jupiter's moons as it passes in front.
2. Eyepieces: You definitely need some new eyepieces. Meade ought to be ashamed of themselves for shipping an otherwise decent telescope with such poor eyepieces. You need to get an adapter that allows you to use 1.25 inch eyepieces rather than the 0.965 inch eyepieces you currently have. I believe MEade gives these out for free if you call them.
Then I would look at the Astromart Classifieds, you should be able to get some decent Plossls for under $20 each. A 25mm or 32mm will give a widefield of view for locating targets and to maximize brightness. You also need something shorter to increase the magnification, preferably two eyepieces or an eyepiece and a 2x barlow. I like something in the 15mm range and with a 2x barlow you would be at 120x, reasonably for most nights. You need decent eyepieces to make this scope work.
3. When using any telescope you need to be aware that atmospheric conditions or "seeing" are a big factor in how sharp the views are. I see you are in Colorado, often the Jet Stream causes the seeing to be poor. Looking through turbulent air is like looking through a mirage, the image is fuzzy and unstable.
Also important are collimation (alignment) of the optics. To get the good views, the optics in a newtonian must be properly aligned. In an F8 Newtonian such as yours, this is relatively simple and not so critical.
Finally, you need to let the telescope cool down to get the best views. A telescope that is taken outside where it is cooler will create its own mirages or "tube currents" which make for poor views until it has cooled. With a 4.5 inch mirror, this will take at leats 30 minutes.
4. Summer is just about here, the summer sky and the Milky Way are here. There are many fine objects in the south, south and east of Jupiter, in Scorpius and Saggitarius, many clusters and Nebulas that are quite nice in a 4.5 inch scope.
5. If you don't own any good quality planetarium software, I recommend the freeware program "Cartes du Ciel." It is powerful and will allow you to look at the night sky from you home location, zoom in and just look for interesting targets.
www.astrosurf.com\astropc
5. I can't help you with your motors except to suggest looking at Weasner's site, he has lots of good stuff for the simpler MEades. Also, www.telescope-warehouse.com has parts, motors and gears for the Meade DS scopes at very low prices.
So, Michael, with reasonable expectations, I think your 4.5 inch Meade could provide you with some very nice views of the night sky. As you are finding, using a scope is does take some skill and understanding, just getting a good sharp focus takes some practice.
Posted 06/21/2006 05:33AM #2
Alright well I took the scope apart, and found a think layer of dust on the primary mirror, and I think that had something to do with the lack of views, that and ofcourse the eyepieces. I've been following all the advice, and checking out the links provided. Sometime this next week I should be ready to start a decent eye piece collection, and get the 1.25" adaptor from Meade (calling in the morning).
In addition to all that, I managed to pick up a 60mm refractor telescope from a local shop for $10; Tasco is the brand and I'm not sure if it's a quality scope or not, but for $10 it's good enough to scan the skys to find interesting objects to look at throught the 4.5".
I also managed to order a used Orion Space Probe 130ST EQ for $180. It looks to be in great condition, and there are lots of good reviews for it. Now the kids can stop fighting. smile
Sometime before the end of the summer I want to get a 8"+ dob (build me own). But that's the last thing on my mind right now. For now I just want to sit back and enjoy what I have.
Thanks again everyone for the help, and the spelling correction. smile I look forward to learning more, and someday returning the favor.
Michael
