Ok I have been looking to upgrade my scope with new eps. plossl seems to be the best all around ep. When I went and searched I found no name fully coated super wide view for practically nothing. Then I seen the same description on name brand plossls no super wide view for sometimes twice as much. Now I am confused more then I was when I started. What do you suggest with a 114mm by 910mm 4.5
plossls so many to choose ?
Started by Dimpa, 03/06/2006 08:30PM
Posted 03/06/2006 08:30PM
Opening Post
Posted 03/06/2006 09:37PM
#1
Albert, Your 4.5 inch reflector is theoretically good for magnifications from 16x to 225x. In reality 150x is probably the sweet spot. If you wear eyeglasses I would get a 20mm possl with decent eyerelief and couple it with a 3x barlow. This way you get good eyerelief and decent magnification, or get a 6mm with decent eyerelief. You don't need to get a name brand radian for big bucks since your scope is F8 a cheap possl will work well. You can find decent eyepieces for $40 to $80 and I would recommend buying a used one from Astromart, they hold their resale value well. I think I would also get a 32 or 40mm eyepiece for deepsky observations. Your scope will show you some nice nebulas and star clusters but will make you want a bigger mirror.
Clear skies
Dave
Clear skies
Dave
Posted 03/07/2006 05:13AM
#2
Check these folks out they have some Plossl packages and the prices don't seem to bad.
http://www.geckooptical.com/anttlers_optics/index.html
The "star" we look at tonight may have exploded millenniums ago. (To progress, we must discern what exists and what does not).
Funding Member
