When putting the OTA on the mount should the focuser be on the top of the tube or 90 degrees from the top? What is the general rule?
Position of focuser
Started by astroham2003, 05/26/2006 02:25PM
Posted 05/26/2006 02:25PM
Opening Post
Posted 05/26/2006 04:11PM
#1
John:
I am assuming from the details of your question that you are working with a Newtonian on a Equatorial mount and that it has rings that allow you to rotate the tube.
The answer to your question is that you put it where it is most comfortable. As you move about the sky, the tube will rotate and change the position of the focuser and you will end up loosening the rings and rotating the tube so that the focuser and the finder are in useable and comfortable positions.
There are rings available that allow you to freely rotate the tube as you wish, these are called "rotating rings" and are very nice but also very expensive, several hundred dollars.
A more reasonable solution is a third ring or clamp above the top ring to keep the tube from sliding down in the OTA and then just leaving the rings themselves a bit loose.
Hope this helps...
jon
Hope this helps...
jon
Posted 05/29/2006 03:13AM
#2
I'd have to say the focuser should only be in whatever spot it is in on its own after you balance the scope. I noticed after I added some heavier accessories to my scope, I didn't have the luxury of choosing where to put the eyepiece. I was subject to whatever the balance said it should be.
Funding Member
