Question Regarding Play in Motor Drives?
Started by Vermel, 09/26/2006 02:33PM
Posted 09/26/2006 02:33PM Opening Post
I finnally got my LXD75 SN 10" in one piece. It's a big scope. When balanced it loads the German Eq mount to a total of 60 pounds. With that being said I have noticed a very small amount of play develop in the RA axis. It produces a noticeable wabble at high speeds. I have yet to train this scope on an object in space or track one for that matter. I guess with a scope of this size and weight this is to be expected but manageable. Am I right or wrong? Have I jumped the gun? Next clear night will tell I assume.
Chris
Posted 09/26/2006 04:41PM #1
Look in your instruction manual for something called "adjusting the worm gears." On most mounts there is some kind of adjustment capability so that the teeth of one gear mate the other better. This is usually the source of this kind of play.
(Although I am a bit confused by--"noticeable wobble at high speed"--How is it you can see it wobble at high speeds?) Are you talking about through the eyepiece?
