Re: beginning imager
Started by jonisaacs, 01/10/2007 03:25AM
Posted 01/10/2007 03:25AM Opening Post
>>And I should add, I've been told that the coolpix compresses data for storage, so information could be lost there, and it may just be that I have insufficient control of how the camera reacts to the intense light of the fully illuminated portion of the moon.
regards
Greg N
I think this is important because there can be significant data lost. Which Coolpix do you have??
Have you tried hand holding single shot??
With my CP 4500, that is works best for me.
jon
Posted 01/10/2007 12:07PM | Edited 01/10/2007 12:10PM #1
Greg:
I have a Coolpix 4500 which is the last of series which included the 995 and the 950 and maybe someothers. The 4500 has a Magnesium body, 4 megapixels and a 4x zoom...
Anyway, I have taken quite a few photos, mostly birds but some on a driven mount and many with a DOB.
I think the biggest issues are focus and vibration. Getting a good sharp focus is a real problem because of the small screen. For both the night sky and birding, the technique that I have found works the best is to focus the telescope without the camera in position using my long distance glasses. I then shoot with the camera either in autofocus or set to infinity depending on the target.
With a bird or DOB, time is of the essence so I hand hold the camera up to a Celestron 32mm Plossl and zoom in with the camera. Hand-holding has the added advantage that if done properly, I am not touching the telescope with the camera, so the vibrations are not transferred from the camera to telescope. The long focal length of the scope amplifies any vibration, I think of it as taking a close up image of the eyepiece. As long as the scope is perfectly steady, the camera isn't a problem.
With a driven mount, I use an Orion Steady-Pix along with a remote, this is normally for long exposures.
I think the key to getting good shots is experimentation, take lots of shots, and develop your own technique.
The photo I posted here previously shows what can be done handholding the 4500 to a DOB and a target like the moon.
http://www.astromart.com/common/image_popup.asp?image=/images/forums/499000-499999/499937.jpg
The photo below is of the Wild duck and I believe I took it with a 130mm F/5 Newtonian with a Paracorr on an EQ-3 mount.
jonisaacs's attachment for post 110643
