Hello all. Didn't know where to post this so chose this forum since none of the others seemed appropriate.
My question is if optical resolution behaves the same way that radio resolution does. As we know, with radio telescopes if you build an array or have two scopes separated by some distance, the resolution of the combination of scopes is determined by the baseline of their separation.
Would optical scopes behave similarly? So in a practical example, if I had a 20" Newtonian, if I placed a mask with two 3" apertures with the outside of the holes 20" apart (i.e., the centers 17" apart), what would be the theoretical resolution of this masked setup vs the full resolution of the 20" opening?
