Thought of another way to install diagonal.
Objective: To install a star diagonal with a Meade 114NT.
Purpose: To build a BiNewt (binoscope).
Problem: Distance from secondary to EP holder is too far.
Observation: Focuser in the closed position intrudes about 1-5/8" into the tube.
Possible solution: Trim the focuser rack and tubing about 2".
Advantages: Not necessary to change the primary to secondary distance. Vignetting avoided.
Before I cut: Remove focuser and measure/determine if the necessary distance would be gained by trimming the focuser. In any event, if a little more distance gain is needed, I could move the primary a bit closer to the secondary with less impact on vignetting than without the trim.
Disadvantages: Dunno.
Comments?
Stu
Comments?
Stu
