What do I do to improve my viewing?
Started by ChristopherJoe, 08/11/2008 04:42AM
Posted 08/11/2008 04:42AM Opening Post
I received a Sky Scout as a gift and it rikindled my interest in astronomy. After two months of relearning the sky I bought the telescope which is designed for the Scout, the Sky Scout 90.
This is my first refrator. I still own a Criterion RV-6 circa 1978 which I love but it needs some upgrades (focuser and repair of drive), and it is hard to relocate in my backyard which is a maze of fences due to a dog and pool. So, I wanted a grab and go scope for here and to bring to my vacation home on Cape Cod where I have better views.
My problem is when I look at anything above Polaris (40 degrees here) I have to almost lie on the ground to use the finder and my chair becomes too high. I'm thinking a right angle finder might solve the find scope problem but I'm not familiar with them. I've seen viewing seats in the astronomy ads but will they swivel low enough?
I am 6 foot 4 and right now the mechanics of the scope and mount are making it impossible for me to look at things higher than Polaris like the Ring and Albiero.
BTW, I haven't bought or sold anything yet (only a member for about a week) but I have read about a 1000 messages and this is the best $12 I've spent.
Solutions please.
Posted 08/11/2008 10:33AM #1
Hi Christopher and welcome to Astromart...
I think you are on the right track with the Right Angle Correct Image finder and the dedicated observing chair.
- Looking at the webpage for the Skyscout 90, it looks like you should be able to use just about any finder with the standard Vixen/Orion/Celestron/GSO dovetail. With a refractor, a right angle finder is much easier to use and the correct image optics will make following charts easier. The question is whether you want a 6x30 or an 8x50. This somewhat depends on the darkness of your skies, but I would tend towards the 8x50 as it shows fainter stars with a still adequate 5 degree field of view. With the right angle finder, the finder's eyepiece is nearby the scope's eyepiece, I like it...
I notice that it points out the SkyScout 90 is specifically made with non-magnetic materials so it will not interfere with the SkyScout. The only part of the finder that might be magnetic would probably be the adjusting screws and the spring loaded third point. A 6x30 finder might fit your old mounting bracket which would take care of this problem.
- The chair: IMHO a dedicated observing chair is the most important accessory one can own. I use the Starbound which allows for the fastest adjustment but there are other good chairs out there.
- I see that the SkyScout apparently has correct image optics, this is most likely a Amici prism which not only erects the image but corrects it right to left. These can be handy but they degrade the image at higher magnifications making planetary and double star views less than perfect. A simple star diagonal will resolve this problem.
- Your RV-6 should be a fine scope, don't expect the SkyScout 90 to provide the sorts of views possible with the RV-6, they had some good optics and the 6 inch mirror gives it a big advantage. I have one, I find the focuser adequate though I think a JMI Reverse Crayford would be considerably nicer.
The motor to repair the drive is no longer available but I have saved some webpages that address this issue and how to make some simple modifications to available motors so they work with the RV-6. I can send them to you if you are interested.
Best wishes, clear skies
