1.25 vs 2 inch diagonal
Started by Mta472, 10/25/2010 01:18PM
Posted 10/25/2010 01:18PM Opening Post
I have a 12 inch Meade LX90 with a Williams Optics 1.25 inch dielectric diagonal. This means my current maximum field of view is only about 31 arc minutes.
If I switched to a 2 inch diagonal would it increase my field of view? If so, by how much?
Would it increase the brightness and/or contrast of what I see thru the eyepiece? If so by how much?
Keep lookin up......Mike
Posted 10/25/2010 02:10PM #1
What size eyepieces do you have?
Posted 10/25/2010 06:36PM #2
A 2 inch diagonal will allow you to use 2 inch eyepieces. The maximum TFoV would be 51 arc-minutes if you had an eyepiece with a 46mm field stop. Brightness, because you could be using a longer focal length eyepiece at a lower magnification, the image could be brighter.
