During my observing session last Saturday evening I spent most of the time on double stars, but I also observed some nebulae.
NGC7331 in Pegasus was well placed for observation. I always apply a 24mm Panoptic eyepiece (63x) when aiming my telescope. With this magnification I always find this galaxy a bit disappointing. However, it bears magnification well, and at 115x and 167x it becomes a very appealing object. I can not see the dark lane visible in photographs, but a sharp brightness cutoff is obvious at the side where the lane goes. Two of its faint companion galaxies were quite obvious, and NGC7335 really looked like a small galaxy, not just a smudge.
Further south in Pegasus I viewed the pair of edge-on galaxies, NGC7332/7339. These galaxies also require a magnification above 100x to be seen well. They are about the same size, but differ in orientation and surface brightness. No particular features could be made out in these objects.
Still further south (3 degrees south of Alpha Pegasi) the barred sprial, NGC7479 is located. This galaxy appeared in a photo in one of the first astronomy books I owned, and therefore it has a special status among the "items in my collection of astronomical objects". Actually it is rather faint, and so far I have not been able to detect its spiral arms. This object is on my to-do list for my next trip to La Palma on the Canary Islands (September, next year). There I expect to capture some detail in NGC7479.
In addition to galaxies in Pegasus, I observed a few nebulae and clusters in Cepheus and Cassiopeia. I'd just like to mention one quite weird object in Cepheus. NGC7380 is a rather loose open cluster with faint stars located not very far from Delta Cephei. There is some nebulosity in this cluster that can be made out without a filter. The O-III filter enhances the nebula quite a lot. Photos show that the nebula has an irregular appearance, but through the eyepiece the cluster/nebula combo appears almost like an equilateral triangle. I quite often experience that my eyes/brain tend to simplify the shape of faint objects and straighten out irregularities. In this case three of the brighter stars of the cluster arranged as a triangle contributes to the illusion. NGC7380 can hardly be characterised as a show object, but it should be detectable with considerably smaller aperture than 12.5 inches.
Inge S
Inge S
