Despite rather poor transparency on Monday evening I managed to observe the four asteroids that are prominent this month using the Astronomical Society of Harrisburg's 17" f/15 classical Cassegrain at 162 (40mm U.O. MK-70) and 259x (25mm U.O. MK-70). I also loooked at a few deep-sky objects along the way (M34, M30, M2, and Eta Persei) as well as two planets.
I started with 15 Eunomia (magnitude 8.2), which was located in Pegasus (p.82, Uranometria 2000.0 volume I, 2nd edition). The next, 7 Iris (magnitude 8.3), was situated in Aquarius (p.103, I) and formed a faux "double star" with a ~8.5 magnitude field star. Moving to Cetus (p.120, II) I tracked down 18 Melpomene (magnitude 7.8) ten minutes later. The fourth and final minor planet of the night was the very first to be discovered, 1 Ceres (magnitude 7.6), which was also positioned in Cetus (p.140, II). Ephemerides for these "vermin of the skies" can be found at http://cfa-www.harvard.edu/iau/Ephemerides/Bright/2002/index.html
I finished the night with Neptune and Uranus at 259x.
Dave Mitsky
Dave Mitsky
