Two fellow ASH members and I had a very enjoyable observing session last night at Piney Mountain in Pennsylvania's Michaux State Forest, despite gusty winds, transparency that varied quite a bit, and seeing that was downright awful at times. On the plus side, the temperature was a balmy 40 degrees Fahrenheit.
Here are a few of the highlights.
I'd brought along the coordinates for the comets currently visible, including the periodic comet 144P/Kushida, which has brightened more than expected and which was an easy target in Bob Werkman's 7.1" f/6 APM achromat and my 8" f/6 Starsplitter Tube Dob, and C/2006 OF2 (Broughton). Comet Kushida was located in Taurus and had a large, irregular coma that was enhanced with Bob's Swan Band filter. As seen through the 7.1", Comet Broughton, which was situated in Camelopardalis, was fainter and had a rather small coma. We had no luck locating C/2006 W3 (Christensen), which was quite low in the western sky in Cygnus.
We viewed a number of deep-sky objects through the big refractor and Bob's new 17mm Tele Vue Ethos. M37 was portrayed quite well and M81, M82, and NGC 3077 made a fine trio. At one point, Bob was looking at some of the objects mentioned in Sue French's January Sky and Telescope column on the Segment of Perseus. A possible open cluster designated FRS 667 lies to the west of the bright open cluster NGC 1528. This magnitude 8.9 stellar group spans 7' and has an interesting shape, resulting in the nickname of the Squiggle Cluster. NGC 1491 is a magnitude 8.5 emission nebula that is a couple of degrees farther west. It was enhanced with a nebula filter. Afterwards, I viewed NGC 1528, FRS 667, and NGC 1491 through my 8" and a 13mm Ethos (94x).
NGC 1499 was striking through the 7.1" refractor and an H-beta filtered 41mm Panoptic. Kemble 1 (Kemble's Cascade) and the open cluster NGC 1502 looked lovely through the 7.1" and the Panoptic.
This time around Bob graciously allowed me the use of his 17mm Ethos, which resulted in superb 1.4 degree true field of views of M42 and the Sword of Orion, M44, M46 and NGC 2438, M47, NGC 2359 (Thor's Helmet), NGC 2362, the Double Cluster, Stock 2, and several other DSOs at 72x. Much to my surprise, plenty of reflection nebulosity was visible when I looked at M45. NGC 2237 (the Rosette Nebula) displayed some nebulosity through the Ethos equipped with an Orion UltraBlock filter. M42 looked great with the filter in place. NGC 2024 (the Flame Nebula) was readily apparent. A hint of IC 434 could be seen but, alas, B33 (the Horsehead Nebula) eluded me.
It can be surprising some times just how much can be seen on what seems to be a mediocre night.
Dave Mitsky
Dave Mitsky
