An anniversary session
Started by Bigdobs, 09/27/2005 12:18AM
Posted 09/27/2005 12:18AM Opening Post
Date - 9/25/05
Location- Lafayette, CA
Equipment- XT8 Orion Dob, 17mm Orion/Vixen Lanthanum, 9mm MA Meade, 8x42 Nikon Monarch Biocs.
Objects Observed- M31, NGC 7662, NGC 7292, NGC 7332
Class- 5 (LM 4.5/5)
I hadn't been able to get out in awhile, and I was pretty excited when I saw the clouds had cleared. I had been doing a lot of reading lately because of the full moon and unfavorable weather, and had a good idea of what I wanted to observe. However, the night started much differently than I expected.
M31
I saw a certain Great Square spannning across a large portion of the sky, and was filled with memories of a year ago, my first night delving into astronomy with my ETX 70mm. I was frustrated with my birthday telescope, so I brought it to Chabot Space and Science Center, where they helped me take off into the celestial heavens. Autostar wasn't working, so I was showed how to star hop. I could still remember the words that came out of my helpers mouth, "See that big Square there? That's Pegasus, now hop down its side like this and you'll see this faint fuzzy. Thats Andromeda."
Finally I was back at the beginning. I could explore the sky as I once did a year ago, except this time, with better knowledge. An overwhelming sense of accomplishment enveloped me as I realized I had made it through the toughest part of amateur astronomy, the beginning. I decided to start where I started a year ago. M31. I wanted to resemble the viewing as closely as I could to the ETX since it is no longer in working condition, so I used my 8x42 binoculars. Immediately I could see more than I could with the 70mm. The galaxy's nucleus was very bright, and the halo surrounding it was almost equal. Comparing this to that barely detectable nucleus of a seen a year ago was one of the most enjoyable things of the night.
NGC 7662
Believe it or not, this was my first time seeing this object. I guess for some reason my eye is bad at seeing blue. I can see green very easily in the Orion Neb. with a 3.5 inch, but the blue almost looks white for The BLUE Snowball. Increasing the magnification did not help either. Averted with the 9mm yielded irregularities in brightness. I could not detect the central star because the nebula itself was so bright.
NGC 7292
When I was cooped up reading for so many days, I decided to give myself a challenge. I made up my mind to go for a well placed tough galaxy, though I was not expecting to be able to see it. I was extremely surprised when I confirmed it. The first observation, it was popping in and out of averted, and I couldn't decide wether I was seeing it or not. I scanned the sky with the binoculars for a bit and went back to it. Sure enough the nebulosity was still there, so I was very happy with that observation. I don't think I would've seen it if I wasn't searching at high power. However, I'm still doubtful of the observation because I've heard reports of it being barely detectable with an 8 inch under LM 6 skies. I've learned to stop basing what I see on other peoples observations, but any outside help would be greatly appreciated.
NGC 7332
I was surprised I had a little extra time to observe another galaxy so I went to Sky Atlas 2000 and found NGC 7332. Unfortunately it didn't list its companion, NGC 7339. I wish I would've had time to research this prior so I could've caught its companion. I was at a pretty high power, so I don't think I would've noticed it. NGC 7332 however, was easy and bright. It was really pleasing.
http://www.freewebs.com/mehball/
Posted 09/27/2005 06:19AM #1
Hello Zack,
Nice post. Interesting to note that you see NGC7662 as white (but why not a white snowball?). After all the colours of emission nebulae are very elusive, and the visual impression may vary from time to time and person to person.
I can't recollect having spotted NGC7292. It is so faint that it should be considered a challenge for an 8-inch scope. Since you were able to spot it, I'm pretty sure you'll be able to make out much nice detail in the brighter objects, like M33, M51 and M101.
Inge S
