An observing session - at last
Started by Inge_S, 04/04/2008 07:00AM
Posted 04/04/2008 07:00AM Opening Post
The weather of southern Norway has not given many opportunities to observe the sky this year. Wendesday evening I had my first real observing session this year - then we had some 90 minutes with dark clear sky before new clouds came in.
I checked the seeing with the double star 38 Lyncis. The split was ok, although the components appeared a bit fuzzy at 167x. In cases when 38 Lyncis is not properly resolved, it is hardly worth while spending the time even with deep sky observations.
The first deep sky object of the evening was the globular cluster, NGC2419 - the intergalactic wanderer in Lynx. I haven't observed this object since I got my 12.5-inch, and was surprised by its size and brightness. In fact it is much larger than the distant globular in the other direction, NGC7006 in Delphinus.
Then I went for a galaxy tour in Leo, starting in the west with NGC2903. This is an object that never is a disappointment. It is large and bright and shows evidence of spiral structure. Many Messier galaxies are much fainter than this one.
The next station of the Leo tour was the NGC3190 group just north of Gamma Leonis. These galaxies are very small in size, indicating that they are very distant objects - my guess is 50 - 100 million light years. NGC3190 and 3193 are relatively striking even at low magnification. 3190 is very elongated, while 3193 appears to be round with a high surface brightness.
The two other members of this group are more difficult to spot. 3185 is larger and more diffuse than the two first ones. 3187 is a very faint smudge requiring averted vision with my equipment and observing conditions.
Then I pointed my scope at the fine double, Gamma Leonis and moved less than a degree eastwards to find the striking galaxy pair NGC3226/3227. These galaxies always remind me of an exclamation mark (!) with the elongated galaxy on the top as seen through the eyepiece. A bit closer to Gamma another object was seen, NGC3222. This one is very faint, and it is important to keep Gamma outside the field when observing it.
Moving still further east and slightly south I spent some time with the galaxy group containing M95, M96 and M101 plus several other galaxies. The most interesting of these galaxies is M95. I have always suspected to see some structure in M95, and this was the case even this time. It doesn't really look like a spiral, but more like a letter, theta (a circle with a bar crossing the centre). This time I was careful to notice the orientation of the bar, and checking with a photo afterwards, I could confirm that my observation was correct. M96 appears slightly larger and brighter, but I couldn't see any detail in it.
Galaxy hopping to M105 is easy. M105 is also very bright, but not very interesting visually. It has two companions, NGC3384 and fainter NGC3389, the latter being at least as large as the other two, but appearing more loose-structured and with much lower surface brightness.
North of this triangle there are several other galaxies. I identified NGC3412 and 3377, but there are more objects in this region.
The second last station on the Leo tour was the trio consisting of M65, M66 and NGC3628. These are probably the best of the Leo galaxies. Particularly I like observing the elongated galaxy, 3628 with higher magnification (167x in this case). Then the obscuring dust band along the galaxy's equator becomes visible. At low magnificaiton it appears just as an abrupt drop in brightness at the side facing the Messier galaxies.
Finally I moved north to a rich group of small galaxies dominated by the galaxy pair, NGC3607 and 3608. A fainter object, NGC3599 was seen at some distance from the bright pair. Increasing the magnification revealed a still fainter companion to 3607. This is NGC3605 which indeed could be seen even at 63x magnification, but became much more obvious at 115x. Further east I also found NGC3626 which is appeared very brilliant in spite of a relatively low integrated brightness.
For those of you who want to make the same Leo tour as I did I recommend to add NGC3521. I didn't observe it this evening, but it is in the same league as NGC2903.
However, I didn't stop my observing session at this time, but contained still further east to the two galaxies M98 and M99 in the Coma/Virgo cluster. M98 is an elongated object, and nice as such, but I'm always surprised that it is so faint - one of the more difficult Messier objects. M99 appears round and fuzzy at low magnification, bur by increasing the power and carefully scrutinising it, its beautiful spiral pattern can be made out. It appears as a considerably smaller and fainter edition of M101.
At this point I made a short intermezzo with two fine double stars. Xi Ursae Majoris is a very fine object, and I always recommend other observers to have a look at this historically significant double (actually a quadruple since the two components are spectroscopical doubles). Then I had to look at my favourite, Zeta Cancri. Under very good seeing conditions I can recognise the close pair as a double at 167x. This was not possible this night, and I had to use my 4mm Radian to resolve it. This is the best triple star in the sky for a telescope of my size.
Then I returned to deep-sky observation, turning to another favourite of mine, the Cocoon galaxy which actually is a pair consisting of NGC4485 and 4490. To me it appears more like a pair of goldfish playing with each other. It is a very good object at 115x with the bridge between the galaxies being a challenge to detect.
Next I moved to NGC4618. This is a moderately bright object without any special features. But I noticed something that I haven't seen before. There was another galaxy in the same field, obviously an object in the 11 -12th magnitude range. I can't find this object in Kepple&Sanner, and just wonder if I made a serious navigation error. Can anybody help me with this? Is a companion to NGC4618 mapped or listed anywhere, or is there another pair of galaxies (separated by some 20') somewhere in the region? I continued my tour and found M94 without any problems, so I find this very strange.
After brilliant M94 I turned to M51, and for the first time this evening I was disappointed by the view. I saw two fuzzy cores surrounded by a faint halo, and nothing more. I started wondering if I had strained my eyes too much, but then I realised that clouds were coming in from the ocean. So this was the end of the observations this evening. In practice there are some 3 or 4 weeks left with dark nights here. So maybe it was the last observing session this season.
Inge S
