Another hymn to 15x70
Started by kulginov, 03/21/2007 08:37AM
Posted 03/21/2007 08:37AM Opening Post
The weather had been bad all month and I was desperate, so when the forecast indicated yesterday that the night (the last dark night of March) could be not totally cloudy, I took a chance and rushed to my dark place with my 15x70 binocular. I observed only for one hour, mainly proceeding with the Messier survey with the binocular.
In the beginning the air was very transparent. Even though Orion was low, I could see, for the first time, the whole extent of nebulosity in M42 making a full circle. A photographic view, only much, much better! The milky Rosette nebula was also very clearly seen, with stars of NGC 2244 shining in the dark space in the middle.
I looked at Messier objects in Taurus, Canis Major, Puppis, Monoceros, Leo and Ursa Major, liberally mixing them with galaxies in Draco, Coma and Canes Venatici and other bright NGC objects. None of them presented any problems for the binocular. Leo triplet seen in the same field was very impressive, with 3628 clearly seen with only slightly averted vision. M81/M82 was a striking pair - M82 was bent and had a dark middle easily seen with averted vision. Normally an easy find, it took me five minutes to locate them near zenith.
Otherwise, it is so easy to find things with this binocular due to its wide field and bright views, I looked at 40+ objects in one hour and thoroughly enjoyed the process. Then a haze came and I headed home.
I think every citizen should be obliged to have a pair of high quality 15x70 by law.
Dmitri
Posted 03/23/2007 10:08AM #1
Dmitri,
Thank you for your interesting report. I have hardly used binoculars for astronomy myself, and sometimes I miss the option to make observations of large fields at low power. I did, however, look through my friend's 20x80 binoculars at La Palma last year, and I was amazed by the view of the Veil nebula.
I have considered getting a pair of astro-binoculars for myself - time will show if I have to pay for the binoculars or the fine for not owning them.
Inge S
