Another small project - galaxies near M106
Started by Inge_S, 02/15/2007 07:33PM
Posted 02/15/2007 07:33PM | Edited 02/15/2007 07:34PM Opening Post
Detecting an object where the exact position is known is much easier than detecting an object by chance. In order to check your abilities, try the following:
Point your scope at the large, bright galaxy M106 (NGC4258) in Canes Venatici. Then examine the region up to about 2 degrees away from M106 and check how many faint galaxies you can see. Don't use a map when doing this - just notice approximately where you find galaxies (rough distance from M106 and approximate direction), and give a short description of each of them to post under this forum.
How many do you find? Any result is of interest - also if you don't find a single one. None of the neighbouring galaxies of M106 are bright. Still I hope you will enjoy this small exercise. Good luck!
Inge S
