Wizard Nebula
Any visual observations of IC2118?
Started by cdculbertson, 02/20/2007 01:41PM
Posted 02/20/2007 01:41PM Opening Post
Aka "The Witch Head Nebula", and located near Rigel in Orion. I have seen many images of this object, but is it possible to see it visually?
Over the years, I have tried to see this nebula in a variety of telescopes, ranging from a 5" apo to an 18" dob, both with and without an OIII filter, but have never been able to confirm seeing it. I actually consider myself a pretty good observer, but this one just seems to elude me.
Doug
Midway, FL
Posted 02/22/2007 10:44AM #1
Hello:
The Witch Head Nebula is seen in scattered light (from Rigel), so you should go for it without a filter. Checking photos of Orion, this nebula is MUCH fainter than the Horsehead Nebula, which I usually find challenging. It also looks to be quite a bit fainter than the part of Barnard's Loop near M78, which I think I've seen once. In other words, I doubt it's visible in an amateur telescope.
Cheers
Mike Connelley
Posted 02/23/2007 02:15AM #2
I observed the Witch Head Nebula on an exceptionally transparent night two years ago using a 101mm f/5.4 Tele Vue refractor and a 35mm Tele Vue Panoptic. IIRC, a broadband filter did improve the view somewhat.
http://www.astropix.com/HTML/B_WINTER/IC2118.HTM
Dave Mitsky
