Galaxy observation from La Palma was very rewarding. During my stay there the Virgo/Coma galaxy cluster was high in the sky together with all the fine objects of Canes Venatici and Ursa Major. In addition several objects in Centaurus and Hydra were within range.
The most notable of the soutern galaxies were M83 and NGC5128. Both of them had a very interesting apperance in the telescope. Of course, I knew beforehand about the peculiar shape of NGC5128, and it didn't disappoint me, although it wasn't very high above the horizon. It must be one of the most unique objects in the sky. M83 turned out to be a very beautiful spiral galaxy, slightly tilted from the face-on position. The spiral arms were not difficult to make out, although not as marked as those of M51.
Even closer to the horizon than 5128 was the large edge-on galaxy, NGC4945. Although it didn't show much detail, it was a very impressive object.
The Hydra 1 galaxy group is also too far south to be observed from Norway. I observed it twice from the Canaries. The first time I noticed four galaxies within the field of view. The second time I applied the 13mm Nagler, and found six. They were all moderately faint fuzzyballs, but it is always facinating to observe tight galaxy clusters and just contemplate on the true nature of the objects.
Slightly further east in Hydra I observed NGC3621. I couldn't make out any detail in it, but it is large and bright and looks very nice together with several foreground stars.
M104, the Sombrero galaxy can be observed from home, but it is very low in the sky, and in a 12.5-inch scope it is difficult to see light at both sides of the dust band. From La Palma it was an awesome object. Being rather small, it stands magnification well, and I found it best with a 9mm Nagler giving me 167x power. I saw photos of this galaxy when I was a kid, and they really trigged my imagination. Therefore it was a very nice experience for me to observe the galaxy at its full splendour through the eyepiece.
All galaxies of the northern sky appeared brighter and better from La Palma. Moving from a place with sub-arctic to one with tropical skyglow probably explains a lot. M101 and M51 were superb objects, and so were M81 and M82. NGC4564 was very long and bright - it sometimes disappoints me when I see it from home.
I still couldn't confirm the spiral pattern of M100, but the spiral structure of M99 and M61 was obvious. We invented a new name for M61 - the "Food processor galaxy", since they had an appearance similar to the knives of a food processor.
In the distant Coma galaxy cluster at least 15 - 20 faint galaxies could be glimpsed in addition to the large ellipticals. It was even possible to see that some of them were edge-on galaxies with different orientation.
I often get the impression of seeing dust clouds in the large, edge-on galaxy, NGC4631 in Canes Venatici. From La Palma this was even more conspicuous. I'm still not 100% sure if my imagination plays tricks with me. Anyhow this galaxy is a very fine object. Nearby NGC4627 makes it even more interesting, and it is even possible to get NGC4656 within the same field of view. Its irregular hook shape was very obvious under the dark skies of La Palma.
Seeing is often considered to be less important for observation of deep-sky objects. My experience, however, is that structural details in galaxies tend to be washed out by poor seeing. Observing from the mountain under excellent seeing was significantly better than from the lower altitude site where seeing was blurry (but the sky still dark).
Inge S
Inge S
